How to make mass pattern continious?
I´m working whit massing in revit and I want to create a divided surface into a mass (I´ts a conceptual model for a skyscraper)
However when I divided the surface and tried to assing a parttern it is not continious whit the subsurfaces of the mas,
Here are some screenshots of the mass and the pattern assigned to the divided surface,
Anyone have any trick to solve this???
Thanks,Captura de pantalla 2017-01-22 21.32.52.pngCaptura de pantalla 2017-01-22 21.33.00.png
Do you have the same U or V, whichever governs the number of divisions you want to control, for adjacent divided surfaces?
I assigned the pattern by fixed distance it's 1 meter by 1 meter. But it's not the same in the surfaces even though I assigned it at the same time. Is there another control to govern the adjacent sufaces?
Don't use fixed distance when you have non linear edges. Use a fixed number of divisions and see how it goes.
I tried using fixed number its much better! but when I zoom in its not quite precise maybe playing with offset will get it more in place, I guess I can work with it.
Thanks for your help!
