Hi all,
I dont find any appropriate way to make folded plate slab staircase in revit.
Just the way around is to increase the thickness of riser & tread. But this will only work till schematic level.
Munazza
Solved by Kimtaurus. Go to Solution.
Create a new stair type, under Type properties change the Run Type (duplicate and rename).
In the Run Type properties change Underside Surface to Stepped and add a Tread and Riser Thickness.
And presto, you have a stepped concrete staircase with finish materials.
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
