how to make contour line solid
Hey there,
How could I make the contour line all solid
I been noticed that if I make the phase as existing, all the contour lines are dashed. If the phase created as existing, and phase demolished as new construction, one contour line is dashed, and the next one is solid.
How am I able to make all the contour line solid, Thanks.
Hello @Anonymous
Have you tried changing the Projection/Surface under Phasing > Graphic Overrides?
