How to make a non-pattern wall texture?
hugo_mpt_almeida
hugo_mpt_almeida
Hey!
I would like to make a non-pattern, non-repeating wall texture, just like the one below.
However, also, while the design itself is non-repeating, these are actually tiles. So, if possible, I would like to merge a repeating material with a non-repeating texture.
Thanks!
SteveKStafford
At first glance...look into Decals and use an image for the artwork. Place finish layer with a transparent material that uses the tile pattern.
Steve Stafford
Sure it can be modeled. Question is, do you have enough time, money and beer?
1480 tiles would create this Pikachu:
If I had to model it, I'd use a Pattern-Based Curtain Panel with the Material (e.g. color) driven by an Instance Parameter.
handjonathan
Hi @hugo_mpt_almeida
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
