So my detail set up is that I have a filter when I place a E, "E" for existing, in the comment of the family it turns it half tone. Everything so far has run smoothly except for one part and that's the detail line. I created a detail line called Existing set to the color gray. When i print to the set up set to Blacklines they come up as black lines. When i print to grayscale. Everything that is set to halftone becomes hard to see. Can you guys think of any ideas or is there a way your firm does it?
Honestly, I just right-click on and override the graphics in the view. Usually it is a black line
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
That does work but the only problem with that is when you copy it from one detail to another the override disappears. Is there a way when you copy. the override stays?
That is how I have it if or detail items but sometimes I require to draw lines from the detail line command. And I am having trouble with the line types.
