How to make a dimension show in a detail component
djn9SY84
djn9SY84
I'm creating a detail component and i want this dimension to show when its loaded.
I want it to load so my line can display its length in real time.
The second image shows what i want to be able to achieve. At the moment a draw the line check the dimension then type it in.
I want a line that i can draw that will show the dimension automatically.
blank...
Does it have to be a dimension?
You can create a shared parameter, make it read the length parameter of the line, load the same shared parameter in detail tag family and tag them that way.
You could create a generic annotation family, add a label, load it in the detail family, and associate the label with the length parameter.
RDAOU
@djn9SY84
See this post...same principle applies.
https://forums.autodesk.com/t5/revit-architecture-forum/dimension-to-something-beyond-crop-region/m-...
djn9SY84
Thanks for your help guys.
I've managed to get it to work.
However the line type i want doesn't load and i want the units of the label to be i meters. (I still want my project to be in mm)
Family:
Loaded:
