How to Make a 3D section view with two section box cuts
sstattelman4GLLM
sstattelman4GLLM
Basically the title says what I am trying to do. Instead of having just one section box I am trying to use two section boxes in one 3D perspective, but can't figure out how in Revit. I'll attach a picture just for clarity's sake. My terribly drawn blue line is where I would like the other section box.
syman2000
You have to create two separate 3d view. One cut one side and the other cut the other side. Once you have to them both cut, you merge it in the sheet view.
mauricio_mssf
Hi @sstattelman4GLLM
There is no native tool in the program to do this, but you can do that, for that you will need to duplicate a 3D view and overlay them, and create a section box for each view. Watch this video.
https://autode.sk/2FVHBDq
It looks better in realistic style because of the edges.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
sstattelman4GLLM
Thank you all this helped a lot!
