How to load Key Junction from Revit into Lumion? (Enscape skewing view)
holl0481
holl0481
I made a Key Junction in Revit. When I loaded into Enscape, the view looked kind of warped and skewed (see attached how it looks in Revit compared to Enscape) and therefore I wanted to give a shot at loading it into Lumion to see if it would look scaled more correctly. Only I cannot figure out how to get the key junction into Lumion. Tried opening Lumion and locating the file but the file appears empty. In Revit there doesn't seem to be a Lumion button like these is with Enscape. I know Revit renders can be very nice but I want it to just be that bit better quality and I have also been excited to learn Lumion for a while now. If I cannot get Lumion working then advice on how to make the image look not skewed in Enscape would also be nice? 🙂
syman2000
You should be able to change to orthographic in Enscape.
holl0481
Thank you so much, it was right under my nose! 🙂
