How to keep parts in Revit seperately? Revit Interoperability for Inventor
travis.designer.vn
travis.designer.vn
Hi
I create a cabinet part and bench part. Like picture below:
When I use Export Building Componet, then export to RFA. I use Revit  to open this Family. They are only 1 model. I can not add material to cabinet and bench seperately.
How can I keep parts seperatly?
Why don't you break up the Export in several Exports -- each with a different set of elements?
travis.designer.vn
Hi @barthbradley
I try export 2 RFA files, then import family in family. this is result:
In this case, they just show cabinet Material file. If I want add Material to Bench. I have to come back Bench Familu. This workflow is not good. Because in real life, we have not only 2 part, but alot of parts.
