How to join these two seperate roofs
parkslanden183
Message 1 of 10
parkslanden183
Having an issue joining these two roofs together. Keep receiving an error with the joint tool no matter where I click.
Replies (9)
Message 2 of 10
Lachlan-JWP
How do you want them to be joined? They appear to be only touching at 1 point.
Message 3 of 10
parkslanden183
I want to join them similar to this but without the dormers
Message 4 of 10
Lachlan-JWP
You need to change the base offset of the verandah roof. It's currently the same as the main roof which means that the top of the verandah roof is higher than the base of the main roof. Cut a section through the building and move the verandah roof down to match the main roof.
Message 5 of 10
parkslanden183
I don't understand too well with the sections. Is it possible to see this in a 3d view?
Message 6 of 10
Lachlan-JWP
Here is the same thing with 3D views.
Both roofs have the same Base Offset:
The verandah roof has been moved down so that the top matches the base of the main roof:
Message 7 of 10
parkslanden183
How do you align your roofs together to joint? I can't get the offset right.
Message 8 of 10
parkslanden183
Oops didn't mean to reply twice
Message 9 of 10
Lachlan-JWP
It's easiest to do in a section view. You can just move the roof down to the height you want.
Message 10 of 10
handjonathan
Hi @parkslanden183
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Lachlan-JWP helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
