How to install Revit 2016 on win 7 as student
Hi
At my school, the are using Revit 2016, but when i try to download it, i can only find 2014 and 2015.
How to get Revit 2016, as Student.
It have to be compatible with Windows 7.
/ Chris
RDAOU
@Anonymous
Download and intall from Autodesk Vertual Agent ...A link can be found in my signature below
After you download it...you need to get an educational Serial # and product key. To do that you need to have a Student account on Autodesk Education Community...log in to their web site, select the free product (2016) + OS + etc and you should received the Key and Serial (Link also found in my signature below)
Once you r done with the above 2 steps... Start Revit and Activate it using the Educational Serial and Key
thanks mate..
but it still does not work.
I download part 1 and 2, but it still says that the system does not meet the requirements.
/ Chris
ennujozlagam
@Anonymous hello, you can check it HERE for the requirements if match with your system. thanks
All you need do my dear is to update your windows 7 service pack 1 and it will work. On how to install, follow this link. watch this
https://www.youtube.com/watch?v=YEo6LiTEpOQ or follows this process.
https://uknow.drew.edu/confluence/display/techdocs/Manually+installing+Service+Pack+1+for+Windows+7+...
Viveka_CD
Hi @Anonymous
Did the recommendations on this thread help resolve your issue?
