How to hide topography, but keep subregion visible
woezme
Message 1 of 11
woezme
Ladies/Gentlemen,
I'm wondering if you can keep subregion visible, while hiding topography......
Replies (10)
Message 2 of 11
You can't. But you can with a Split Surface.
Message 3 of 11
gsucci
yeah, you can, but it's one of those Revit thing...
Hide the topography in view, then reveal hidden elements, then tab-select the sub-regions and un-hide in view...
Silly, but it should works.
regards
gio
Message 4 of 11
woezme
Okay....i tried and it worked nicely
thanks
Message 5 of 11
wicked cool hack, @gsucci. You should get a wicked cool lil' green check mark for that one.
Message 6 of 11
thanks
I'm guessing the solution was the wicked cool hack that @gsucci told us about. No?
Message 7 of 11
If you have a ton of subregions and you need to hide the maintop in several views, then give the main topo an ID such as Name or Mrk or Comment = Main topo, then create a View Filter to hide it based on the ID criteria.
Message 8 of 11
woezme
yes
Message 9 of 11
kempbrandon1
Great, thank you so much. This really helped me during a project. This should be stated in that part of the software explanation
Message 10 of 11
JKspace424
this did not work for me.  Is it different for later versions of revit?
Message 11 of 11
gsucci
This still works in Revit 2022.
Are you following the given tips?
regards
gio
