How to hide edges of trees on a perspective view?
The edges on the default RCP trees are very distracting and they cover my building, I made the surface of the trees transparent so I can see the building behind it. one time for a few seconds there was a glitch where the edges on the trees did not show and it looked perfect. I was wondering if there was a way to completely hide the edges, these are the methods I have already tried:
- Halftone: does not make the edges transparent, just gray
- VG override the line-type to one that has a dot and a space of 1000': still shows as a solid line (can you make a line-type with nothing on it?)
- VG override the color to a dark green to match the fill of the trees: looks weird since the fill has transparency and the edges don't (can you add an alpha channel to the color?)
- VG override line-weight to lightest (can you make a line-weight that's 0.0"?)
- Line-work tool to invisible lines: only makes edges gray plus really slow picking each line on each tree
- View filters using the same VG overrides mentioned above: same results.
Frank
