How to hide doors / window in a 'setting-out' plan
desmond_grace
desmond_grace
Hi there
I have created a General Arrangement Plan complete with Walls / Doors / Windows etc.
I have now been asked to create a 'setting-out' plan which only shows the Structural Walls.
All doors / windows are to be hidden and the full wall is to be shown instead.
Any thoughts on the best way to carry this out?
Thanks in advance
Des
desmond_grace
Thanks barthbradley.
Is there a way to show the structural wall where the wall / door are? I know it could be done with fill regions, but is there a way that's more efficient?
Des
Des
Phasing and Infills will get you there.  For example, if Walls are placed in the Existing Phase and Windows/Doors are placed in New Construction Phase, then Infill Walls will be placed in the Existing Wall where the "future" Doors/Windows are placed.  Get it? And this is all schedule-able.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-317406A0-ACF8-404B-B9BD-739010A41AB3
Parts might be another approach here that could work as well.
 https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-DA150C6B-996C-4C70-9E8C-3C536C232851
Keep walls in phase 1, add a new phase 2 for all fenestrations and set the set-out view to phase 1 is the easiest solution.
