So, after more thought and trial and error, I think I finally have the question I want to ask (Stick with me here).
Example:
- Tender/CD model archived.
- Construction Admin has commenced
- CO #1 required changes (changes created but still waiting on approval)
- CO #2 required changes (quick response, approved & added to the model)
- CO #3 required changes (quick response, approved & added to the model)
- Decision made to scrap CO #1 as it cost too much.
Question..... How do I revert back to model as was prior to CO #1, while still keeping Co #2 & CO #3?
I can see an answer coming here for the above problem....
Archive the model after CO#1, continue with the existing model and input CO#2 & CO#3, then when CO#1 is scrapped the you just delete the archived model.
On the other hand, what if CO#1 gets approved, you will then have to open the archived model and input those changes to the new existing model.
This is what I call.. 'Double Jobbing!'
Do I make sense here? Imagine this scenario in a much more complex project with multiple changes in different areas of the building within each CO. And then having 100 CO's.
I have done a lot of research trying to find a good explanation/process of how to deal with Construction Admin in Revit. Very little info out there, but surely this happens. Project Managers in my office sometimes make the change and hope for the best, or create a sketch and pdf it and undo everything, wait for approval and then input the changes to the model (if it is approved). This is not efficient.
