Is there any option to create the slots and bolts holes in timber beams through using Revit 2019 steel plates and bolts?
Hi Thanks for the quick reply, Unfortunately, this is not working with me. Are you using Revit 2019?
I am trying to model the timber beam and using the Revit 2019 steel plates with bolts to the timber beam .all good except the bolt holes and plates slots cannot be cut?
Yes the screenshots I showed are from Revit 2019. Did you change the material for model behavior in the timber family?
Still same , I am unable to cut
Bolt holes working fine ,But the plate slots need to cut ?
