How to globally change fonts
david44A6W
Message 1 of 14
david44A6W
I work with multiple production builders.  Each has their own preferred font. I need to be able to change all fonts in a project, including the ones imbedded in families without having to manage different family libraries.  I'm using Revit LT.
Any suggestions?
Replies (13)
Message 2 of 14
HVAC-Novice
You can select one of their  texts (or tags), then "select all in project "and change it to your font family. You have to do that for each of their types.
Arial is kind of the default in Revit. I'm surprised the vendors go through the effort to use a less legible font.
Revit Version: R2026.5
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 3 of 14
mhiserZFHXS
Like Enkus said. There is no fast way to do this, only less slow ways. You could put together a Dynamo script to do it, but even that would take awhile to run if you have a lot of families in your project. If the builders you work with are making you do this, I sure hope you're incorporating all of that wasted time into your fees.
Message 4 of 14
Replace the Windows font files, system wide.
Message 5 of 14
mhiserZFHXS
That seems like overkill that could have some unknown consequences if not managed well 😅. Especially for an issue that shouldn't exist in the first place.
Message 6 of 14
It is the only way to change every text style, label style, dimension style in Revit.  Save different fonts to different folders, rename them all to Arial, then overwrite the original Arial in Fonts folder.
Message 7 of 14
dnufferQS3L9
I don't believe Revit LT has access to Dynamo
Message 8 of 14
dnufferQS3L9
This sounds like the easiest and the most dangerous if not done correctly. please tell me more.
Message 9 of 14
david44A6W
I've been working with them for years in AutoCAD. A couple had mentioned that they wanted to switch over to Revit, but they don't want to have to redo all of their in-house standards.
Message 10 of 14
david44A6W
agreed, please tell me more
Message 11 of 14
What do you want to know?
Message 12 of 14
david44A6W
So, speaking in AutoCAD terms, I take it you're talking about setting up a separate profile for each client with a separate file location for the "arial" font for each of those profiles. Copy the correct font file into that file location and rename it as arial. My understanding is that ttf fonts have to be installed. Which would mean I would have to re-install the arial font everytime I changed from Revit to another Windows application. Am I understanding this correctly?
Message 13 of 14
michaelbrummett58
Observer
Observer
That won't work, Arial is a Windows protected font.
Message 14 of 14
ctm_mka
i would suggest making separate templates for each company using their font as needed. lots of upfront work, but then all you need do is start a project from that template and away you go.
