How to get the Prefix in a Sheet Number Label to show in a Drawing List?
Andrew.Borkowski3V5ST
Creating cold form framing assembly shop drawings. Each assembly sheet needs to have "FRA-" as a prefix to the drawing number.
I modified the drawing number label in the sheet family to have this prefix. Prefix shows on sheet but does NOT show in a sheet list or the Project Browser. Why is this? Any workaround for this?
  • Add a text parameter to Sheets category but do not enter any value
  • Add a combine parameters including the one above and Sheet number, add FR prefix under the combine parameters properties. This will present your sheet number in the schedule.
  • Hide the actual sheet number column from the schedule
