How to get rid of 0 in dimensions (metric)
ajr0
Message 1 of 13
ajr0
Hi
I have some dimensions that has '0' in them which I can't get rid of without deleting the entire dimension line and starting over. I searched and found some responses to tick suppress 0 feet under the project unit setting. I don't have this option as it's greyed out and I'm using millimeters. I have tried changing to feet, ticking the box and changing back but this doesn't work.
I've tried manually shifting the witness lines but that doesn't work either.
Any clues? Thanks in advance.
Replies (12)
Message 2 of 13
Try "Custom" with 0 Rounding Increment.
Message 3 of 13
ajr0
Thanks - just tried that but it says 'invalid input'
Message 4 of 13
Yah. Guess I goofed with that suggestion. he, he.
So, Suppress trailing 0's is grayed out?
Message 5 of 13
ajr0
I've tried that already, won't remove those pesky zeros.
Might just have to redo the dimensions argh!
Message 6 of 13
Wait a minute!  Are you saying that redoing the dimension eliminates the "pesky 0"? So, it isn't replicable?
Message 7 of 13
You change the wrong setting. Do not change Project Units, edit the dimension type and format the dimension type units.
Message 8 of 13
kunle22
Observer
Observer
None of these suggestions worked for me
Message 9 of 13
Are you sure that these dimensions you a trying to change are actual dimensions - and not replacement text?
Message 10 of 13
Corsten.Au
Hello
Do yo think its cause you picked two references at the same location.
try this if thats the case.
Witness LinesWitness Lines
Corsten
Building Designer
Message 11 of 13
skyblueskiesS6E6W
Because my zero was in the middle, I couldn't seem to select it, but if I deleted one dim on either side, I was then able to select it and delete it.  Not ideal, but better than starting over on the entire string.
Message 12 of 13
dabramsky
I don't understand the 4 steps. Step 2 and Step 3 both instruct to edit witness lines.  But once I enact edit witness lines in step 2, it is now greyed out in step 3.   Please advise
Message 13 of 13
Sleepingfish_Kuo
Because you are editing the witness lines now. (just like editing floors or stairs but without check when finish).
Just go back the view and click elements to remove or add some reference.
