How to get all used materials in Revit
I want to know is there a way to check whether the material is used in project or not.
Or is there way to check for certain material whether it was used in project or not.
I have some materials with missing textures. and I want to know if that material is used in the project or not, in order to solve the problem about missing texture applied to that material.
L.Maas
Use purge unused. Then you will get a list of elements including a list of materials not used.
Cancel out the command if you do not intend to purge anything.
The materials not in the list are the ones used in the project.
Louis
Please mention Revit version, especially when uploading Revit files.
or create a Multi-categories material take-off schedule
jklynsma
Purge unused worked great for me.
purvigirwin
It doesn't tell you WHERE they are used, but in the materials browser you can view by "Show In Use" and "Show Unused"
Purvi Gandhi Irwin, AIA, LEED AP BD+C (she/her)
_____________________________________________________
Owner/Technology Consultant
Shifted Paradigm Design, LLC
Autodesk Expert Elite | Revit Certified Professional | Autodesk Certified Instructor
