How to FORCE the closing of property lines that dont loop
luispavon
Message 1 of 10
luispavon
Any plugin available?
Replies (9)
Message 2 of 10
If you are entering the lines by coordinates, let the table close the loop instead of trying to enter the last coordinates.
Message 3 of 10
How to FORCE the closing of property lines that dont loop?
Don't put in last line segment. Instead, let Revit close it.
Message 4 of 10
Just curious about something, @luispavon.  You asked if there were any "Plug-ins" available.  I'm wondering if this is maybe what you are after?
https://www.youtube.com/watch?v=0YSMwyT_UUk
Message 5 of 10
Why do you need a plug-in?  The function is built in the program.
Message 6 of 10
luispavon
How do I do that?
Message 7 of 10
You don't recognize the dialog box in my screenshot? How are you creating the Property Lines?
Message 8 of 10
luispavon
Im using the sketch option, but the lines that im using as base are very little and I select them, but cannot get the property line closed therefore it does not create my property line, nor calculates the area.
e27f9961c2fa3f71194bd5a9c9879a06
Message 9 of 10
To access the dialog box I showed above, select sketch and click Edit Table.
...you are going to need to fudge it a bit to close it. You can delete line in Table and let Revit decide on line to replace and close it with, or just let Revit close it by adding a last sketch line to the ones you have.
Message 10 of 10
You can interpolate/simplify where the segments are too small for Revit to draw.  Keep in mind that you are drawing a parcel element, not a fine jewelry.
