How to Fix Warped Foreground Pattern when adding split lines on floors?
JsphH11
Message 1 of 18
JsphH11
I'm creating a Shower Floor, When I add a Split line and create a trapezoid shape for the floor to slope into the drain, the Tile Pattern Warps. The reason I'm using a trapezoid shape and not a square shape is because the longest sloped lines create that shape when toucing the drain perimeter; when directing those lines to the center of the drain. When I fix it and change it into a square the warp stays but I have to reset the floor and do it all over again with the square and the warp is are gone.
I found the following:
https://forums.autodesk.com/t5/revit-ideas/site-models-fix-hatch-patterns-for-shape-edited-floors/id...
I'm posting the question just to check if its something that can be fixed in Revit 2023. Else I'll just stick with Rectangles and squares.
Replies (17)
Message 2 of 18
hmunsell
what is your ultimate goal for the tile....
  • are you just wanting straight lines on the sloped floor like this
  • or are you wanting to do the arched tile lines as shown in your original post?
Howard Munsell
Message 3 of 18
Floor was enlarged and then cut down to shape by In-Place Void Extrusion. Then I went to work on it with Modify Sub-Element Tools and a blow-torch.  😉
Message 4 of 18
Message 5 of 18
JsphH11
I want it like the image you posted, where the tiles are squares, not curves.
Message 6 of 18
hmunsell
sorry got busy with my day job... LOL...
I just used one of the showers you had there already and adjusted the fill pattern. Stuff like that happens all the time. Patterns don't place exactly where you want them. But it is easy enough to fix.
Howard Munsell
Message 7 of 18
ARRGH! Why didn't I go there? I had to make a mountain out of a molehill. Rotating and aligning the Model Pattern didn't even cross my mind.  Guess I'm an official nincompoop.  😉
Message 8 of 18
Maybe I'm not a nincompoop after all. You can't rotate and align the deformed model hatch pattern on the shaped-edited floor.
Message 9 of 18
@JsphH11 : Use 1 Point at -17 (or whatever negative value is appropriate) at the center of the drain.  Delete the others.
Then rotate and align pattern.  That's how I would roll.
Message 10 of 18
hmunsell
Hmmmm looks like I might be the nincompoop then... 🤣
ill have to take a look at that
Howard Munsell
Message 11 of 18
No you're not.  The OP still needs to use your solution.
Message 12 of 18
hmunsell
i was still able to do it to this one.... set the 4 internal points around the drain to 27 (from 44). then rotated and aligned the pattern lines. when i first started to adjust the internal points, they got all wonky, but straightened out after the 4 points were the same. either way... looks like we got 2 ways to do it :-).
Howard Munsell
Message 13 of 18
Are you sure you opened the OP's RVT and not the one I posted?  If so, I can't do it.  What's the secret?
Never mind. I get it. I'm just going take you at your word.  It makes sense.
Message 14 of 18
I think we ought to share that solution credit.  I think you brought more to the table than I did.  Just calling it like it is.
Thanks.
Message 15 of 18
hmunsell
nothing special... just selected the surface and modify Sub Elements. I've honestly never seen a pattern go so wonky like that before.
i think it has to do with the shape at the drain. when I straightened it out and make it more rectangular, vs parallelogram, the lines didn't distort when i doped the center points.
Howard Munsell
Message 16 of 18
hmunsell
Absolutely, id be honored 😁
Howard Munsell
Message 17 of 18
JsphH11
Hi @hmunsell yeah that one I could fix with the align tool just as you demonstrate.  I was trying to fix the ones that have the pattern warped(with curves), the simplest solution is to avoid complex (non square) geometry as my friend @barthbradley suggested just to place one point instead of the quadrilateral non square plane geometry I was trying to attempt.
Message 18 of 18
JsphH11
I cannot visualize unfortunately  I don't have revit 2024, but I would to try to get to see it soon.
