How to fix my roof?
How to fix my roof?
How to fix my roof?
I am wondering how to fix my roof so that I can see the slope in the floor plan. It currently look like this.
How 'bout an Underlay?
mauricio_mssf
1 - Does your roof go down with a slope that you would like? If not, edit a big one.
1.1 - Otherwise, you can select the roof and change the slope
2 - You can elevate the section plane of the view.
2.1 - In the viewing range - cutting plane - Offset
3- Create a floor plan from he level above.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
ennujozlagam
you can share your file so we can check? thanks
