How to fix hole between wall and window
MBBIM
MBBIM
Im still on the old 2015 LT and wondered if there is an easy way to close the hole between window and wall without doing some complicated family adjustments.wall.PNG
Select the wall, right click on the blue end grip and choose Disallow join, then drag it to touch the mullion.
MBBIM
Superb that did the job.
Many thanks from the Netherlands.
Looks to me like that design doesn't work. You have a partition wall that conflicts with the window and door location, or vice versa.  Maybe I'm misreading the plan, but it looks like you're trying to make a square peg fit into a round hole.   Just saying.
MBBIM
Its maybe not the best solution as it may give a warning that constructions cross eachother but it worked for me.doorwall.PNG
