how to export revit 2016 model into 3dsmax 2016 full with light and texture
how can export revit model with light and material into 3ds max? whenever i export from revit to 3ds max all texture will be vanished and its wasting time to give material to model in 3ds max again! any solution??? please help
dzanta
export the revit model as fbx file format
or
if you have bdsp/u installed, you can use the suites workflow command within the application menu.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Thank you for your respond may i know what is Bdsp/u? What application help me? I want my 3d model can be import in 3ds max software with light and texture ! If there is any application i can install to help me please let me know I want my model fully from revit into 3ds max Please help me !!! Appreciate in advance 🙏🏻🙏🏻🙏🏻🙏🏻
ennujozlagam
hi dzanta is correct export to FBX but you must be in 3D view.
BDSP = Building Design Suite Premium
BDSU = Building Design Suite Ultimate
it is a autodesk sofware.
If you have this software installed in your PC then you dont have any problem exporting to .FBX - 3DS max.
Thank you.
No i don't have any problem for exporting revit to 3ds max with fbx!!! The problem is the fbx file which is exported from revit is not included light and texture!!! At least tell me How can i export revit file to unity with texture and light! ?
ennujozlagam
ahh. okey. you may check it here. maybe could help you. thanks.
http://download.autodesk.com/us/3dsmax/2012designtutorials/index.html?url=files/GUID-9028FB7D-F2F4-4...
akaz.warman
Observer
Observer
Doing that only exports geometry but doesnt bring in textures
