How to eliminate " Type Selector" Help PopUp dialog in familiy editor
YairaGabay
Message 1 of 39
YairaGabay
In Revit 2022 family editor , whenever I  save the file ,I  get the popup Help dialog "Type Selector"
How can I disabled  this dialog? I just dont want to see it
Yaira
Replies (38)
Message 2 of 39
Sounds like you are doing a "Save As" and not "Save".
Saving Files | Revit 2019 | Autodesk Knowledge Network
Message 3 of 39
YairaGabay
Hi
It does not matter if I do save or save as
The dialoge jumps and mostly on the writing line and can not be closed
BTW, I'm working with Revit 2022, It did'ny happen to me in the previous versions
Message 4 of 39
YairaGabay
Please, see my reply
I worte it by mistake on the main post
Message 5 of 39
Are you using a keyboard shortcut? Something other than CTRL+S?
Message 6 of 39
YairaGabay
No
It just popup whenever I save the file
Message 7 of 39
RSomppi
Are you loading it into the project when saving?
Message 8 of 39
YairaGabay
I'm not sure I understood your question.
When I work on a project and try to save the file, a help message pops up and sometimes hides important information. I do not want any message to pop up and I do not know how to cancel it. Apparently it's something to do with system settings and I can not find how to do it
Message 9 of 39
RSomppi
It seems that your issue is not clearly stated. It would be beneficial to upload a screenshot of what you are talking about.
Message 10 of 39
Do a Repair Installation. Know how?
How to reinstall or repair your Autodesk product | AutoCAD | Autodesk Knowledge Network
...you could also try deleting the Revit INI file and letting Revit rebuild a new one upon launching.
The Revit.ini File | Revit | Autodesk Knowledge Network
Message 11 of 39
YairaGabay
Message 12 of 39
RSomppi
That's what I thought you were talking about. Try going around the type selector on your way to save to prevent it from popping up.
Message 13 of 39
YairaGabay
Hi
It does not seem to me that something went wrong in the app. I also did not see anything strange in  revit.ini
anyway I am afraid to do a reinstall
Message 14 of 39
RSomppi
Reinstalling probably wouldn't solve the problem.
Message 15 of 39
YairaGabay
Hi
Sorry' I don't understand what to do, Can you explain me please
Message 16 of 39
I didn't say to do a reinstall. I said REPAIR.  It's safe to do. Promise.
Message 17 of 39
YairaGabay
Hi
The Repair operation will overwrite my custom configuration?
Message 18 of 39
@YairaGabay wrote:
Hi
What kind of custom configurations are you referring to?
Message 19 of 39
RSomppi
I've seen this across multiple versions, machines and places. I doubt a repair will solve the issue. Avoidance is probably the best solution. Also, after it pops up and before hitting any other buttons, move you cursor over the type selector again and it goes away.
You could ask if @barthbradley has ever experienced this. I've got a feeling that he is guessing.
Message 20 of 39
It's called troubleshooting, my man.  And, no; in 10+ years with this software, I've never ran across this specific issue. I'm not even convinced it's a Revit software issue. Regardless, I'm very comfortable with the advice I've imparted herein so far.  If it is unhelpful to the OP, then I would suggest that the OP contact Autodesk directly via opening a Support Case.
