How to edit and customize the UniformatClassifications.txt file
SteveFong
Message 1 of 12
SteveFong
I can't find any documentation on how Revit interprets the UniformatClassifications.txt file.  The logic of the Keynote file is well documented, but I can't find any information on the assembly code files.
When opened in Excel it looks like this:
UniformatClassifications_2010.txt - Excel.pngUniformatClassifications_2010.txt - Excel.png
Revit interprets this as:
Choose Assembly Code - UniformatClassification.pngChoose Assembly Code - UniformatClassification.png
I am having a hard time understanding the logic of how this works.
Column D must be related to the Revit Category.
Can anyone point me to a reference?
Replies (11)
Message 2 of 12
Alphabetical order....
1: Top Level
.... 2: Secondary Level
........ 3: Sub-level
............... 4: Itemized
etc...
Message 3 of 12
There's also add-ins for managing, changing , adding assembly codes.  FWIW.
Message 4 of 12
SteveFong
Thanks, but I tried that already, and it didn't work.  Further, Column D is important for something, I think categories.
I am looking for comprehensive instructions from Autodesk.  I have been unable to find them.
Message 5 of 12
SteveFong
I didn't describe my goal.  I am at the investigation phase of trying to get my uniformatClassifications.txt to match RS Means.  This would require that I basically rewrite the .txt file, but I need to understand its formatting well to be able to accomplish this.
Message 6 of 12
SteveFong
So, I had tried this, but apparently I had some sort of problem in my formatting.  I think you are correct!  Thanks for the answer.
Message 7 of 12
When you use Excel you need to export it to a certain format of txt file for it to work...Think it is uniformat...but I could be wrong.  I usually just use the text editor.  In the case of the Keynote file I use Keynote Manager, which the format is very similar.
Message 8 of 12
Column D does refer to Categories. For instance "-2000011" is "1;Model;Walls;-2000011;;True;False"
Message 9 of 12
Oh....btw...
"Note: Autodesk does not recommend or support edits made to the Uniformat data file (UniformatClassifications.txt) located in %APPDATA%\Autodesk\Revit\<product name and release>."
Message 10 of 12
Samuel.Arsenault-Brassard
"Autodesk does not recommend or support edits made to the Uniformat data file (UniformatClassifications.txt)"
This is frustrating...
Here's a modified version of the file that works using common sense and can be edited.
To do this fix, I've replaced the undocumented and arbitraty code (-2000011) with the proper code in the first column. To do this, I had to count the number of characters in each cell of the first colums
=LEN(A1)
, then assign a level based on the length characters
=IF(B2=1, 1, IF(B2=3, 2, IF(B2=5, 3, IF(B2=8, 4, IF(B2=13, 5, "Other")))))
Then I did IF statements to capture the appropriate level below and concatenated each column into a final result. Now the file is useable using the common logic.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-99AE9D3E-3326-4F21-ADC5-303F2E1A2135
Message 11 of 12
I did a three aprt video series on this problem today if you're curious, the fix is detailled in Part 1 & 2. It explains how to go from a custumized Uniformat Excel document to a Revit Keynote classification file. It also explains why the default Uniformat classification file is lacking and should be skipped altogether.
Estimation in BIM - Part 1 - Proper Formatting in Excel
https://www.loom.com/share/4a4c44c4eff841ff8527fc46abd5eb7a?sid=215e08da-17bb-4419-b304-c0482f3c9b2c
Estimation in BIM - Part 2 - Accurate Revit Keynote File
https://www.loom.com/share/c5f1f82f536b4196b37fe8118b9660bc?sid=a2b94a89-0f71-4c37-9362-caab2be6a20d
Estimation in BIM - Part 3 - Construction Data, Standards & Collaboration Philosophy
https://www.loom.com/share/1eaeb2c413f04ee1b7c001d64a132815?sid=1c5227bf-99bc-4ce5-85b9-5bf08b89d10e
Message 12 of 12
SteveFong
Great Videos!  Thanks for breaking it down and showing your code.  Love the method and your philosophy in Part 3.
