How to edit a window tag from a project?
danezeq
Message 1 of 18
danezeq
how can i edit family of a tag inside a project? or just export it to file outside of revit porject?
Replies (17)
Message 2 of 18
kadmonkee
select the tag , select the edit family button on the ribbon
inside the family editor select the Label (text) select the edit label button on the properties palette add or change the parameters the label is reporting.
adjust the width box to avoid text wrapping
do a save as to a common location for future use.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 18
danezeq
On  this specific tag, i dont see the "Edit family" buttun on the ribbon.
on other tags - i can see this buttun. why is that?
Message 4 of 18
kadmonkee
it is not a tag
it may be text
or text within the family
or part of a linked file
can you share a screen shot of what you are describing?
thank you
Message 5 of 18
danezeq
it is a tag, just a different one:
https://www.youtube.com/watch?v=FMNZ979YW2Y
Message 6 of 18
kadmonkee
in the video when you changed the selection you could edit the family.
edit the family and do a save as to what you want it to be select all instance and change them to what they need to be.
thank you
Message 7 of 18
Kimtaurus
Can you find the family in the family browser?
Maybe you can open it from there (or save and open).
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Message 8 of 18
danezeq
Yes i did that in purpse to demonstatre that in some tags, the edit family lacks from the ribbon.
Message 9 of 18
danezeq
i tryied it. i dont find any option to find/save it from the project browser.
Message 10 of 18
kadmonkee
so if you did that intentionally you answered your own question
edit what works don't create things that don't work
thank you
Message 11 of 18
danezeq
That's just an example. I have another tag which I want to edit, and it doesn't have this option on ribbon.
Message 12 of 18
Kimtaurus
Could you maybe share the file?
(Delete as much as you can from the model to minimze file size)
Message 13 of 18
danezeq
yes. it's on revit 2018. will you be able to load it?
Message 14 of 18
Kimtaurus
Sure, upload the project or post a download link if the file is too large.
Message 15 of 18
danezeq
here is the file
Message 16 of 18
Kimtaurus
I think I know what the problem is. When was this file or template originally created? Older versions of Revit didn't have the "Edit Family" option or even a save option for loaded families. This option was added in version 6.0 apparently.
I'm guessing this file was created with a template that was continued from an older template, where those families were never updated.
http://www.cadsoft-consult.com/blogs/architectural-technology/2009/08/unable-to-edit-a-revit-family/
You're only option is to recreate the window tag and load it.
I would advise also removing this old family from your template (or give your template a proper update).
Message 17 of 18
danezeq
Thank you for this! i had no idea.
Message 18 of 18
Kimtaurus
Also, the M in front of the family name indicates this is a standard Autodesk family. You'll probably find a newer version in your Revit 2018 library.
C:\ProgramData\Autodesk\RVT 2018\Libraries
