How to draw parametric ceiling like the image shows?
Could someone teach me how to draw the parametric ceiling like the image shows? Or are there any youtube videos I can watch? Because I did not find the tutorial videos for this kind of ceiling on youtube. Thanks a lot.Parametric Ceiling.jpg
syman2000
You most likely have to get into adaptive component. First you have to create your profile. You can do it using workplane and use 2d spline or you can use points and spline thru points.
Create adaptive profile base on the shape you want.
For horizontal profile you want to divide path. Set it to distance and use segment length.
Once you have those blue dot, adapt the family to those blue dots. Then use the repeater to adopt to the reset of the lines.
Add those segment parameter
Once you set those parameter, you can play around with the sample with 800mm width
Sample with 600mm width.
I am including this HyunWoo Kim video since you specifically mentioned "parametric".  Many of his videos were very helpful to me in learning how to do this (e.g. hosting and driving Ref. Points' "Offset" via Family Parameters).
Revit Tips - Adaptive Umbrella - YouTube
Check out his other videos here:
HyunWoo Kim - YouTube
Thanks, I will try this way
Thank you, I will watch the videos
Thanks, I will watch them
