How to DRAW an ellipse
How can I draw an ellipse whith several or its points at sonme small vertical distance form the ellipse's work plane?
chrisplyler
I am not certain I understand your question.
You can only draw on a work plane. Just like you can only put pencil on paper. You can't make pencil write a small vertical distance above the paper.
Now, some elements can be offset from their origin. But otherwise you're going to need to make a new work plane where you want to draw.
Alfredo_Medina
Please provide more information. Are you taking about the elipse that results from sectioning a cylinder by a slanted plane?
L.Maas
If I understand correctly I assume gergon44 is talking about an ellipse bend in 3D space.
Something like this example?
(Sweep along object with 3d picked path)
Louis
Please mention Revit version, especially when uploading Revit files.
