- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
I'm slightly desperate to draw a mono-pitched cone section-shaped roof. As you can hopefully see sketched out in the attached sections, there are basically an inner and an outer circle with a different gradient each, between which the roof should span.
I have tried
- drawing a simple conic roof of which I then cut the top - doesn't work due to the geometry
- creating a component (a Sweep / Sweep Blend with 2 points) - at least that connects a roof to one of the circles but I don't see how I could modify the shape to attach to the other circle's geometry correctly
- creating an in-place mass - Revit connects the sweep to a solid shape but then won't finish the sketch since "Sketch is no longer parallel to its defining plane". Pictures see attached Trial image.
A couple of days ago I somehow got the entire building shape to sort of work as a conceptual mass (except for some angled walls; see Trial image) but I would like to only import the roof as a face if anything and then use Model by Face in the project file.
I would be incredibly thankful for any help!!!
