How to do more customizable fascia
3 REPLIES 3
DrakeCanyonArchitecture
406 Views, 3 Replies
I'm trying to figure out how to do a more customizable fascia or at least be able to accomplish the look in the attached picture. I need to do something like the "two cut plumb" roof. I would rather handle the look with the cut on the fascia rather than to roof slab, as the roof height is set to "extend to core" and is exactly where it should be. Is there a way to do this?
BTW, by more customizable, I'd love to be able to cut and miter facia just as I would on the jobsite.
Kevin Mendenhall
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
3 REPLIES 3
What about modeling your Rake Board with a Roof Type?
...Voila! 2x12, 2-Cut Plumb Rake Board!
That's a great idea! I'll mess with that a bit and see if I can get the same results. I'm wondering if I will be able to join or miter to the next run.
Kevin Mendenhall
@barthbradley , great solution in that I can get exactly the look that I'm looking for. It takes a little time compared to the facia tool, but it's great to know that this option is there. Thank you for the solution!
Kevin Mendenhall
