How to do a curved stairs
AIDANJHAWKINS3HJ6V
AIDANJHAWKINS3HJ6V
Hi there,
Please see drawing of the stairs I want to replicate:
I have tried to do this stairs by sketch but it doesnt recognise it.
I know there is a U shaped stairs already, so I am wondering is it possible just to edit this to get the curve, and how would I do it?
Aidan
It can be done via sketch. Your sketch is wrong.  Boundary lines are only on the right and left sides. All other line work is Riser lines.
Your sketch doesn't work because you draw every line using boundary line.  Only use boundary line to draw the two side edges of the sketch, use riser line to draw steps.
constantin.stroescu
have a look at my screencast:
(view in My Videos)
Constantin Stroescu
handjonathan
Hi @AIDANJHAWKINS3HJ6V
Thanks a lot for posting your question to the forums!   Has the solution suggested by @constantin.stroescu helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
