How to determine the total length of multiple lines
lucilarosso
Message 1 of 59
lucilarosso
This is something that used to be very easy to do in autocad (with a polyline) and checking the lenght on the properties bar.
When I select multiple lines (chain of lines) the "lenght" data is greyed out.
I hate having to measure every segment separately! It has to be easier... right?
Replies (58)
Message 41 of 59
bill_gilliss
@Alfredo_Medina wrote:
Or, maybe faster, without checking Chain, is: Measure > Measure Along an Element. Hover the mouse over the first item, hit the tab key, and click. The result of the total length would be in the options bar.
Alfredo - Doesn't work here in Revit 2019 with model lines or detail lines. Alas. - Bill
Message 42 of 59
Homsey-CCH
You can use "measure along an element" and tab+select a chain of model lines, except for curves.  Revit 2019 will report the total length of connected straight model lines in the upper left corner of the screen.  If you have a curved segment, you will have to select it individually and the length of the curve will be reported in the Properties box.
You can tab+select a chain of lines and toggle them all back and forth between model and detail lines as needed.
Message 43 of 59
MarkRummings1764
It is amazing what one can learn. In all the years of using Revit I had not realised this feature was there. Very useful.
Message 44 of 59
aruckerY7D6L
While I was looking for an answer for Revit, I can use this if I export to AutoCAD. Thank you
Message 45 of 59
Peter-Christensen
Why does everything in revit have to be so difficult? AND, measure 'tool' only measures straight lines. What if I want to measure a chain of lines that includes arcs and/or splines?
Why is Revit the industry standard? It mystifies me.
Message 46 of 59
Peter-Christensen
It cannot be done 'easily'.
I can create a chain of lines. I can select the chain of lines. WHY can I not see the length of the chain of lines?
Message 47 of 59
Model lines only.
Message 48 of 59
Peter-Christensen
Doesn't seem to work on non-straight lines
Message 49 of 59
Message 50 of 59
Peter-Christensen
Thanks for the tip. I assume you've done that in a conceptual mass. Would be nice if I could do it in the project, without having to create a new model to do it in; may as well just dimension all the line segments and sum them in excel.
Message 51 of 59
It was done in a project.
Message 52 of 59
Peter-Christensen
OK, revit help said to do it in a conceptual design, however I now see that it can be done in a mass in a project. Thanks
Revit help:
'Divide a path' (https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M...)
...leads to 'Create a Conceptual Design' (https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M...)
Message 53 of 59
aruckerY7D6L
This video explains it https://www.youtube.com/watch?v=yEazSiqolHY. You can also start with the Massing & Site tab and use In-Place Mass in the Conceptual Mass ribbon. Draw your line and you can see how long it is. Thank you @ToanDN
Message 54 of 59
nj19790605
I really hate it .
so many years .   revit Can't solve such a simple problem.
I hate it.
Message 55 of 59
kb4NXFP
Community Visitor
Community Visitor
I switched to Archicad… problem solved 🙂
Anyway if I recall right switch from detail to model lines, or oposite, tab on a Line to select connected lines and you should be able to see the length of them. I think.
Message 56 of 59
979997853
Community Visitor
Community Visitor
it also does not work like that on multi-splines.
Message 57 of 59
Alfredo_Medina
@kb4NXFP
I would not call this a problem.
As mentioned before: if it is a chain of model lines (or a chain of walls), do this:
Modify > Measure along an element > select the first segment > use the Tab click to select the whole chain. Done.
The total length is in the left side of the Options bar.
If it is a chain of detail lines, do this:
Modify > Measure along an element > activate Chain> click on the start point of the chain, then in all the endpoints until you get to the end of the chain. Done.
The only limitation I see is if the chain includes arcs. It works well with straight segments.
Message 58 of 59
phLB628
WINNER!!!! What a great suggestion - thank you 😁
Message 59 of 59
blank...
Old thread, but there is a Dynamo script, comes with Revit you don't have to do anything except run it. Works on detail lines, model lines, combinations of those, straight, curved...
Run player, select Calculate Total length of lines.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=RevitDynamo_Dynamo_Player_Sample_Graphs_Calculate_...
