how to determine a model or reference point coordinate direction in revit
Message 1 of 19
Hi.
I have a problem on my model point offset parameter, as seen in this video that I have created few point snapping on existing point, but when I offset the Height distance in those points, some were going up as expected and some more were going down follow to Z axis which is not my expectation because all points should be the same even up or down.
Please advice me how to solve this issue? and what is usually determine the point direction to facing which side ?
Hepi
https://file.io/Mc9Dqz
Replies (18)
Message 2 of 19
bin
Just saw a post recently talking about the mass work plane direction something like that.
Maybe we should have an extra tool beside the Show work plane tool - Flip work plane.
Message 3 of 19
Watch the Work Planes you are hosting points to. They are different for the second two.
Message 4 of 19
Hi @barthbradley
I have been watching this video and trying to remake a new point onto an existing host point, as usually I set the reference plane at the existing point then place a new point. I could not find any different except the Z direction is still the same problem, one face up and other face down.
so far  I only found one similar case and idea in youtube :
https://youtu.be/2Td2oRsoj6k
In that video, he fixed it by using another new parameter with (-) negative value to force it located on the same Z direction.
im not sure is it the only way or any other more efficient solution for this situation.
Please advice me further. Thanks
Message 5 of 19
Hi @bin
yes, i agree if there is any tool to make the reference plane flip. However I have tried to use flip in property menu, this can enable the coordinate of Z direction turn up, but it didnt make any effect to the offset parameter, it will still go down rather than follow to flip direction.
I just found in here : https://youtu.be/2Td2oRsoj6k
This could be one of the solution and im still looking for the root problem and other way out possibility
pleade advice me further more if you have any idea too, thanks
Message 6 of 19
It looks like you are trying to host a Ref. Point to another Ref. Point so that that Ref. Point's Z offset distance can be associated to a Parameter.  I don't know exactly how your family is set up, but it looks like you Hosted a Ref. Point to a Divided Line Node. Is that correct?  If so, you just need to Host the next Ref. Point on the correct Work Plane of the first Ref. Point.
That make sense?  If not, just post your family and I'll do it.
Message 7 of 19
hi @barthbradley
as seen in my earlier video that im actually hosted a reference (model) point with another point, Please kindly check this attachment file of the family, you will find my problem is around adaptive point #2 area... there are few points along the other 2 lines got problem with Z direction. I dont know what make the Z direction different with the my other points and dont know how to avoid same issue to happened again in my next exercise. Please check it and help me out. thanks 🙂
Message 8 of 19
Hi @barthbradley
I enclosed my family file for you to check and correction about Z direction.
so far I only use another (minus value) parameter to force Z direction up and align with other reference points.
do you know what is the root cause that make Z direction up or down ? how to avoid this issue and do you think is there any other way to correct this besides this minus value parameter method?
thanks and regards,
Hepi
Message 9 of 19
it hard to understand what you are trying to do.  Would make it easier if you named/numbered your points.  Hosted points would be named/numbered like their Host but with an extension.  For example, if a point is "driven by" point "A", then name that point "A1".  Maybe even "A1-z" to indicate the direction (z) that it travels from "A" as well.   Just a suggestion.
For now, could you post a picture diagramming what you want.
I see that you did post a diagram in your latest post. I think what you are looking for is Point "Rotation" -- a point property. Enter 180 degrees reverse the Z direction.   Does that help?
BTW, if it doesn't rotate about the axis you want, that means your point is hosted to the wrong work plane.  You need to replace it (e.g. delete and create another one on the right work plane).  That's the only solution.
Message 10 of 19
I have tried to use flip, mirror, rotation angle to turn Z direction, but all are still fail. You can try that family, i have attached it in previous message. naming a point also didnt work for this case
Message 11 of 19
It would work for me -- or anybody trying to help you.
Message 12 of 19
So, which point are you having trouble with???  Be nice if you could say "A1-Z", but you can't unfortunately because they aren't named.
Message 13 of 19
those red dot points is troubling me, I fixed it with negative value parameter because I dont know what else method can z direction issue. I beg your pardon about naming suggestion, because I dont understand how to use naming point to solve Z direction, would you please explain further more with any picture or short video?
Message 14 of 19
Dude, I am not seeing what you are showing in your screenshot. You sure you gave me the right file?
Message 15 of 19
yes, this is my earlier file and I also sent my latest one in upper messages above, maybe you missed out the latest file.
but the issue is still the same about Z direction
Message 16 of 19
Is this what you are trying to do?
Message 17 of 19
Yes, in curious to turn Z direction up, flip can make it, but flip won’t make any effect to the Z direction travel path when I input the value in parameter if i keep use the same parameter (H_small ; H_mid ; H_big —> parameter) as same as other points, unless I make the same value in negative, please have a look into parameter property, when you change those points to original parameter from (H_small_rev1 ; H_mid_rev1 ; H_big_rev1) return to (H_small ; H_mid ; H_big) then you will see that flip doesnt make the effect at all.
what I actually wish to see is Z direction can be turn the same way for all points and all of them use the same parameter, if it is possible. So when i input any value then everything will run to the same travel path and distance.
for this purpose, flip does not work.
Message 18 of 19
bin
I’ll just use x=-y formula, move them to Other category and create new parameters in Dimensions category.
Message 19 of 19
Like I said earlier, you can't correct it after-the-fact. You need to redo it and put it on the correct work plane.
