How to: curved mesh facade panels
JensVrancken
JensVrancken
Hi everyone, first time on the forum so correct me if i’m posting this wrong.
Is there a way in revit to create curved mesh panels for my facade, as shown on the reference image of SANAA’s building.
if not, how should i try to do it?
rxi.gg
Curtain Walls are your friends
https://www.youtube.com/watch?v=hAs235c2uuM
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
You can create it as a thin wall with a mesh material.
So you prefer jumping through hoops to create a curved curtain wall instead of simply draw a curved wall?
JensVrancken
Do you know how the mesh material would have holes like the actual mesh?
Make the material with cutout so it has holes in realistic/rendering visual style, and semi transparent with a surface pattern in hidden/ shaded visual style.
https://youtu.be/IxSovnnFxpU
JensVrancken
Thank you so much!
