How to create this 3D organic linear shape?
lilflor
lilflor
The wrap around shelter area at the endThe wrap around shelter area at the endJust the organic shapes going upJust the organic shapes going up
How would I go about creating this structure on Revit?  I can model in place and create a sweep, but is there a way to twist the lines around and make them go upwards?
Also, would I create the curved black shelter as a wall and just curve it?
Thank you!
Create it under as a mass or an adaptive family:
- Place points and create spline through points. They can be moved in any direction X, Y or Z by select each point and drag it based on the axis guide
- Draw a profile on the spline, select the profile and the spline to create a form
- Move any of the points and the form will follow
Basic Wall and Roof System Families can be applied directly to Mass Forms/Families directly within the Project Environment.  Wall by Face and Roof by Face tools are found on your Site and Massing tab.
