How to create dashed lines for window openings?
holl0481
holl0481
2021-04-05 00_23_57-Autodesk Revit 2021 - [KingoHouse_HF_Final design - Sheet_ A101 - Unnamed].png
How do I individually select the window lines to make them dashed? When I select the solid lines it selects the entire window and there's no options in properties to manipulate just the graphic visibility of the lines. There doesn't even seem to be a way to remove the lines. My school requires the lines be dashed so that it indicates they are not a physical entity. What would you advise me to do?
Typically, those Swing Lines are assigned to a Subcategory of the Windows Category.  Open the Family, select the Swing Line and look under its Properties to see if it is assigned to a Subcategory and which one.   You can change the Line Style used by a Subcategory through the Project's Object Styles or through the View's  Visibility/Graphics Overrides.
holl0481
Thank you, I went into family and there was no Swing line subcategory, I checked properties again and there was nothing there and tried in edit family and in edit family the window swing lines don't show.
This is the window I am using: https://www.bimobject.com/en-us/aluprof/product/mb-70_casement-window-2-sash
holl0481
Solved! I messed around a bit more and finally got them dashed, thanks for the help! 🙂
That Screenshot work for you?
I would recategorize them to  "Elevation Swing" - but that's me.
holl0481
That's cool, I never knew about object styles, thanks for teaching me about that! 🙂
