How to create custom Hatch Pattern
tstewart
Message 1 of 15
tstewart
I'm at wits end on trying to make a custom hatch pattern...HELP!!!
Replies (14)
Message 2 of 15
nmarcelis
Based on the images provided are you sure you're trying to create a hatch pattern (.pat).
Could it be that you mean creating a new material texture?
Revit Certified Professional Architecture, Structure and MEP.
Message 3 of 15
tstewart
I want to add them to the Hatch patterns, so they can be used under Filled region (Annotate). Is there a way to show those patterns as hatch patterns?
Thank you,
TS
Message 4 of 15
It would be a difficult pattern to create using a .pat definition, but there is an AutoCAD pattern named Gravel that you could import.
Message 5 of 15
tstewart
Where can I find the import?
Message 6 of 15
Pattycake_Kyle
We created Pattycake cause this is an issue with current AutoCAD and Revit abilities. https://pattycake.io/
We have the largest free library of PAT files (300+)... if you search 'cobble' or 'rock' for example, a couple will pop up. We also have the ability to draw in web, or import a DXF to PAT. Both of which would allow you to customize a .PAT for yourself, but part of our PRO suite with limited features in the free.
Sounds like you are using revit, if so [check here] for custom import steps.
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Message 7 of 15
nmarcelis
I will try to record a screencast on how to do it later tonight, if you still need help by then.
Message 8 of 15
martijn_pater
You can import the .pat file here, as shown below. To create custom patterns you could use a plugin like PyRevit or using pattern generator as shown by @Pattycake_Kyle
Import custom pattern / .pat fileImport custom pattern / .pat file
Message 9 of 15
hugha
Unfortunately the examples you provided are bitmaps unsuitable for use as vector-based fill patterns.
If you are seeking to fill a region with coloured pebbles then you should apply your bitmaps as a material.
If you are looking to fill a region with a traditional pattern suggesting such pebbles then you should seek or construct a .PAT file.  Fortunately there are a number of websites offering pattern collections, some containing fills showing rounded stones.  Here is a list of them: https://www.hatchkit.com.au/HatLinks4.php
hth,
Hugh Adamson,
www.hatchkit.com.au
Message 10 of 15
martijn_pater
You can apply the vector pattern to the foreground pattern and a solid fill to background though.
Also if you want some sort of coloured pebbles you should be able to do it using a repeating detail component (so annotation, not as material hatch pattern however).
Message 11 of 15
AutoCAD's GRAVEL, Gravel pattern:
Message 12 of 15
tstewart
BB:
That was the issue…not a Material, but a Hatch pattern. I was asking the wrong question. I wanted a Hatch pattern and you told me how to add a Material pattern. It hasn’t worked for the stone pattern.
Thank you,
TS
Message 13 of 15
tstewart
Martijn:
How is that task done (i.e., vector/Background combo)?
TS
Message 14 of 15
martijn_pater
Either this is a material setting, so you first import the pattern under 'Fill patterns' and then in material browser you can create a material and set which patterns to use. Or as filled region, you can create/duplicate a new type and under type settings set the fore- and background pattern you want, as well as color. See below.
Pattern settings in Material GraphicsPattern settings in Material Graphics
Type settings for filled region annotation.Type settings for filled region annotation.
Message 15 of 15
nmarcelis
Im glad you found a solution for your issue.
