How to create a proper hexagonal curtain panel?
Hello, I have created a mass in the project and I have created the hexagonal pattern panels using pattern based curtain wall family but the problem is that when I apply the pattern to the mass, the parts where the pattern cuts doesn't continue with the frame material.
dzanta
In those areas where the panel is working properly, you will need to create an adaptive curtain panel and manually place them via adaptive points.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
