how to create a new assembly code file from scratch
tcardia
tcardia
I am trying to write a new "assembly description" file, however it seems that Revit does not read the lines that I write, for each line it gives me this result "the line is incomprehensible".
As a base I am using a file that Revit reads and this is the format I am using
(code)[space](description)
01 description
Does anyone know why that happens? Or do you know what type of encoding to use to create this file?
Simon_Weel
Is this related to your other post about Assembly Codes?
tcardia
Solved!!
(num.)[TAB](Description)[TAB](num.)[TAB]
byeee!!!
TC
