How to connect the beam to the column without gaps
Caed9
Message 1 of 11
Caed9
Hi, Revit community,
Is there a way to remove the gap between the foundation beam and the foundation column?
I already tried looking on the properties palette to see if there was an option, but all I see is y and z justifications.
I just want to remove the gap, could you please give me some advice on how to adjust it, I also tried changing the material on the beam to match the column, but the gap was still there. And when I tried to join them  I get a message that says that they are already joined.
Thank you
Replies (10)
Message 2 of 11
Zero out the join cutback.
Message 4 of 11
Betcha yours is reading "Wood". Choose "Concrete".
Message 5 of 11
_Vijay
Try with beam/Column joint tool as in image.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 6 of 11
Caed9
I tried editing the family but it was in concrete, I changed to precast concrete to match the column.
But the gap is still there
Message 7 of 11
Man, I though for sure that was it.  Well, I guess no parade for me tomorrow. Arrgh!   Post the file if you want.
One more thought: any nested shared  components in this booger?
Message 8 of 11
Caed9
hi, I fixed it with the start join cutback and end join cut back in the properties palette , I set them to 0.
Message 9 of 11
That was the first thing I said! Yippie!
Parade back on?
Message 10 of 11
Caed9
Thanks @barthbradley I was looking for that option in the properties palette and could not find it, I thought it was only for steel beams.
Message 11 of 11
