how to color differnt rooms in revit with the same color
siwar.bouaoun
Message 1 of 13
siwar.bouaoun
Replies (12)
Message 2 of 13
So your question is "?" ?.
Or, is the title of the thread the question? How to color different rooms in Revit with the same color?
HUH?
Message 3 of 13
hmunsell
assuming your using the Color Scheme? it depends on the criteria you are using to color by. Department, Name, etc...
you can open the Color Scheme and edit the colors as needed. pick the color you want to change and assign it the same color as what you want.
Howard Munsell
Message 4 of 13
siwar.bouaoun
Je veux colorer des pièces qui ont des noms différents avec la même couleur
Message 5 of 13
Hein?
French Humor.
Joking aside, can you post a picture or two?
Message 6 of 13
patrick.emin
Hi @siwar.bouaoun FYI we have a French forum here: Revit et BIM - Français - Autodesk Community
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 7 of 13
siwar.bouaoun
Sorry for posting a french message
I want to know how to color rooms with different names with the same color
with no specified category
Message 8 of 13
Message 9 of 13
hmunsell
then what i show above should work for you. is it not?
Howard Munsell
Message 10 of 13
Peut-être. Peut-être pas.
Que Sera, Sera.
Message 11 of 13
hmunsell
my wife is learning French.... i usually just smile and nod when she starts talking. i barley speak English well and i was born here.
Howard Munsell
Message 12 of 13
rayketchman
What an unhelpful thread. I have the same question.
Message 13 of 13
hmunsell
@rayketchman there have been several options provided. i have seen no replies as to why any of them did or didn't work. if you are having a similar issue, may i suggest starting a post in the forum with your specific issue and let's see if we can help.
Howard Munsell
