How to change units in wall thickness type
paula_frankowska97
paula_frankowska97
Community Visitor
Community Visitor
Hi!
Im a beginner in Revit. How do I change unit in wall thickness selection? I have changed generally project units for mm, and it works when I'm drawing a line, than it shows lenght in mm, but when I want to change wall thickness I have inches instead of mm.
vitorbortoncello
Change length to mm:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Are you saying that you want the Project Units for Length to remain in Millimeters, but you want to enter Inches sometimes? Did you know that Revit will automatically convert values to Project Units? In other words, you don't need to change Project Units to convert millimeters to inches. Just use the inch symbol (") after the number.  It will automatically be converted to mm.  12" will become 304.8.
handjonathan
Hi @paula_franko
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
