- Mute
- Permalink
- Report
Hi all,
In Revit are you able to edit the transparency of a filled region similar to AutoCAD?
In AutoCAD you can set the transparency from 0-100 but in Revit i can only see two options of either 'Opaque' or 'Transparent' under the edit type feature.
Surely there's a way to edit the transparency of a filled region in Revit?
Many thanks
Link copied
