- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm purging an existing architectural model of a 18 story building for to use as a site model for a fit out to several levels. I want to delete the unnessicary levels in the existing architectural model, however there is one curtain wall that has been customized for a specific mullion set out. I don't want to edit this existing model, I just want to limit it to 4 levels and remove unnessicary info.
I can adjust the height of the curtain wall to the 4 levels with the edit profile tool and mullion set out remains unchanged. I cannot find a way to change the associated level without causing the mullions to be deleted. Any ideas? Much appreciated.
