How to change an extrusion material?
Does anyone know how to change an extrusion material to compound ceiling?
I have created two arrays group. The first array consists of compound ceiling and the second array is an extrusion object. The purpose is to run solar analysis and get the cumulative insolation on the ground. The compound ceiling array is able to reflect cumulative insolation on the ground but not on the extrusion object. The difference between the two arrays are material and also angle of panel. Please refer to attached PDF and Revit files for details.
Thank you.
Thum
