how to calculate footings formwork?
Message 1 of 11
My question is how to calculate with Revit formwork areas for footings.
thank you!
Replies (10)
Message 2 of 11
Ilic.Andrej
Depends what you need. If you need the total area (vertical surfaces), you could model the formwork before you calculate it. It could be some simple parametric line-based family.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 11
constantin.stroescu
use  Calculated Parameter Fields:
  • 2*(L+W)*T   for Column foundations
  • and 2*W*T for Wall foundations
  • use Filter to isolate Wall and Column foundations
  • have a look at the attached file
Constantin Stroescu
Message 4 of 11
How can we model formwork in order to calculate area for footings?
columns and walls ok, but what about footings, strip footing?
Message 5 of 11
constantin.stroescu
Message 6 of 11
Ilic.Andrej
I don't care if its a wall formwork, column formwoork or foundation strip formwork. I can use the same parametric line-based family to model it all. Its attached.
Btw, I wanna thank you for posting this question. Right now, I'm working in construction and maybe we are going to use this family that I built for you.
Andrej Ilić
MSc Arch
Message 7 of 11
You are welcome! But this library is it available online? where can I find it?
thank you so much for your help
Sorry now I noticed that you attached this .rfa. file. how can I apply it ?
Message 8 of 11
Ilic.Andrej
Just load into project (insert/load family). Create a component (Architecture Tab/Component)...Draw the line. Explore instance properties and type properties of this family.
Andrej Ilić
MSc Arch
Message 9 of 11
hello again, I would like to ask you that now that I used this component for formwork how can I receive the quantities from View-Schedules, in order to find the quantity in sqr.m for my take off? thank you in advance
Message 10 of 11
Ilic.Andrej
Open type properties of the family. You will see a material parameter. Assign a new material and call it "Formwork". Create a material take-off schedule and check "Generic Models". Add these fields: material:name material:volume There s no need to add [material:area] because you would not get the area you need. [material:area] calculates all the surfaces of a generic model. This is not a floor or a wall where you would get an area of one surface. Instead of that, create a calculated value called "Area" and give it a formula: [material:volume]/50mm Input the formwork thickness of your choosing.
Andrej Ilić
MSc Arch
Message 11 of 11
Ilic.Andrej
...the family is updated. It can be used to create beam formwork as well.
Andrej Ilić
MSc Arch
