How to build shipping container models with corrugated surface patterns or bump?
Message 1 of 11
I am working on a project and it says that bump-ups and bump-outs are encouraged. Is it possible to create these in Revit? If so, how?
Replies (10)
Message 2 of 11
arkitek2ss
can you be a little more specific?  where does it say this?
almost anything is possible in Revit.
Message 3 of 11
Are you talking about remodel / expansion of existing buildings?
Message 4 of 11
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member.Welcome to the Autodesk Community! Smiley Happy
Are you talking about bump maps? Which version of Revit do you use?
Message 5 of 11
I am building a shipping container house. I need make things like the pull
out sides of an RV.
Message 6 of 11
Sahay_R
You can model-in-place geometry in the project environment, or you could model face based families (that's the option I would prefer)
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 7 of 11
Viveka_CD
Hi @Anonymous
Check this screencast on shipping containers by Tracy Chadwick
This thread has some interesting workarounds on modeling shipping containers.
Let me know if this helps!
Message 8 of 11
Viveka_CD
Hi @Anonymous
How are you doing?  I'm checking back to see if you've made progress on the shipping container model?
Feel free to add pictures if possible.Looking forward!
Message 9 of 11
When I need to make corrugated walls, I generally use a curtain wall.  If you create the profile for the infill that is the same as the plan shape of the corrugated wall material (starting and ending with a piece that is 1/2 the length of the others so that it tiles properly) and using no mullions, then the wall will appear as a solid panel.
Message 10 of 11
bimscape
Carefully consider whether the corrugations actually need to be modelled- or can they just be represented with a surface pattern. Always consider whether all those extra faces of geometry (which have an overhead) are adding value
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Message 11 of 11
Time to switch to ARCHICAD?
