How to attach an excel graph into an element (line o family) in Revit
Good afternoon to everyone,
I would like to attach an excel graph as characteristic (or whatever) of a vertical line in revit.
I've carried out some measurement of moisture in a wall, one for each 20 cm proceeding in vertical. As result, I have from 15 to 20 couples of value (height and moisture) that I should use to make a diagram.
In revit I want just see a vertical line which is linked with this graph.
There is a standard way to do it?
Thank you all in advance
Kind regards,
Andrea
MostafaElashmawy
I'm sure that can be addressed with Dynamo.
Mostafa Elashmawy
Corsten.Au
can you show some sample output you are looking for?
Corsten
Building Designer
